Multiflex TES A 8010 GSA 1 NAT
danboh
- Страна, Регион, Область: Земля
Здравствуйте! Подскажите кто что производит из данных материалов какой результат от его применения? Нужно ли сушить? Какой температурный режим формования для литья под давлением? И т.д.?
serj364
Re: Multiflex TES A 8010 GSA 1 NAT
Вот описание, правда по-аглицки:
Multi-Flex® TES A8010 GSA1 NAT by Multibase (Dow Corning) is a recyclable, general purpose thermoplastic elastomer (TPE). Contains anti-blocking additive for polyethylene (PE) film extrusion, anti-slip, processing aid, anti-fibrillation additive for polypropylene (PP) yarn extrusion and weaving, stiffening agent for polypropylene (PP) films and plaques. Is a soft touch, easy to color, halogen free, oxygen scavenger, breathable, heat weldable (corners), and heat stabilized grade. Exhibits UV resistance and very high flow. Possesses lower coefficient of friction, excellent mechanical properties at elevated temperature (>90°C), hydrocarbon- , chemical- , tear- , heat- , scratch- , mar- and fluid resistance, low taste, odor and extractables. Shows compatibility with polypropylene (PP) and polyethylene (PE), long term adhesion stability, spinning cycle up to 1600 rpm, improves mold filling, reduces cycle time, durability, good desiccant- and peel properties. Provides lower extruder torque, improved thermal insulation, impact protection, noise and vibration dampening, low and high temperature flexibility. Designed for injection molding method. Possible applications of Multi-Flex® TES A8010 GSA1 NAT are health, personal care, houseware, portable electronics, hand & power tools, sports and leisure. Can also be used for electrical protection, wire and cable, packaging, window seals & gaskets, fluid and product delivery. Complies with UL-94 V0 Flame Rating, KTW/A, W270 and W543 “LGA” and is food contact approved (FDA and 2002/72/EU).
Более детальную информацию можете запросить у производителя
danboh
Перевел: Multi-Flex® TES A8010 GSA1 NAT от Multibase (Dow Corning) - это перерабатываемый термопластичный эластомер общего назначения (TPE). Содержит антиблокирующую добавку для экструзии полиэтиленовой (PE) пленки, противоскользящее, технологическое вспомогательное средство, антифибрилляторную добавку для экструзии и плетения полипропиленовой (PP) пряжи, придающую жесткость пленку и бляшки из полипропилена (PP). Мягкий на ощупь, легко окрашиваемый, не содержащий галогенов, поглотитель кислорода, воздухопроницаемый, свариваемый при нагревании (углы) и термостабилизированный сорт. Показывает устойчивость к ультрафиолетовому излучению и очень высокий поток. Обладает более низким коэффициентом трения, отличными механическими свойствами при повышенной температуре (> 90 ° C), устойчивостью к углеводородам, химическим веществам, разрывам, нагреву, царапинам, марам и жидкости, низким вкусом, запахом и экстрагируемостью. Показывает совместимость с полипропиленом (PP) и полиэтиленом (PE), долговременной адгезионной стабильностью, циклом прядения до 1600 об / мин, улучшает заполнение формы, сокращает время цикла, долговечность, хорошие свойства осушителя и отслаивания. Обеспечивает более низкий крутящий момент экструдера, улучшенную теплоизоляцию, защиту от ударов, демпфирование шума и вибрации, гибкость при низких и высоких температурах. Предназначен для литья под давлением методом. Возможные области применения Multi-Flex® TES A8010 GSA1 NAT: здравоохранение, личная гигиена, домашняя утварь, портативная электроника, ручной и электроинструмент, спорт и отдых. Может также использоваться для электрической защиты, проводов и кабелей, упаковки, уплотнителей окон и прокладок, подачи жидкости и продуктов. Соответствует UL-94 V0, классу пламени, KTW / A, W270 и W543 «LGA» и одобрен для контакта с пищевыми продуктами (FDA и 2002/72 / EU).
serj364
Вы лучше напишите с какой целью и куда хотите приспособить данный материал, ибо конкретно этот материал может никто из присутствующих форумчан не пробовал.
На пленки и нити не смотрите, смотрите в применение. TDS в открытом доступе не нашел на данный материал, но осмелюсь предположить что это ТЭП с твердостью по Шору А 80 ед.
danboh
Пробовали лить ручки, и заливать изделия с арматурой, на ощупь мне (личное мнение) материал понравился (приятный), с арматурой изделия заливаются , но на мое изделие не хватает текучести, т.е. текучесть хуже, чем у пластиката О-40....(или может температуру можно было пробовать еще поднимать - температуру ставил как на SEBS). Вот стало и интересно, может кто, что еще с него пробовал делать....serj364 писал(а): 28 янв 2019, 20:29 Вы лучше напишите с какой целью и куда хотите приспособить данный материал, ибо конкретно этот материал может никто из присутствующих форумчан не пробовал.
serj364
Температуру выше 210 не рекомендуется поднимать, ибо выше 210 идёт деструкция материала. Чтобы развеять сомнения по поводу текучести, запросите паспорта у производителей данного ТЭПа и пластиката (а лучше всего - самому измерять ПТР этих материалов).
Это на российском или турецком ТЭП (на китайском SEBS) нельзя поднимать температуру выше 210 С, на европейском ТЭП (на европейском SEBS) можно поднимать до 230 С.
serj364
Спасибо, буду знать.Maks42 писал(а): 29 янв 2019, 22:17 Это на российском или турецком ТЭП (на китайском SEBS) нельзя поднимать температуру выше 210 С, на европейском ТЭП (на европейском SEBS) можно поднимать до 230 С.
Совсем загнивают европейцы, стабилизатора для своего SEBSа не жмут, куда им до продвинутых китайцев
Там ещё дело в том, что китайский SEBS недогидрированный и в нем есть большой остаток двойных связей (SBS), которые начинают окисляться при 190 С.
- serj364 • Serge андрэ
