Необычный модификатор перерабатываемости ПВХ
gammaplast
Re: Необычный модификатор перерабатываемости ПВХ
#31 Сообщение gammaplast » 20 дек 2010, 16:11
выдержка из таблицы которую даёт китайский завод по производству акрилатов.
IMPACT MODIFIERS MBS
LB-22 Transparence, high impact B-22,BTA-712,C-132
LB-621 High transparence, less crease whitening B-521、BTA-707
LB-717 .High transparence, less crease whitening BTA-717
LB-56 Superior impact B-56、C-223、BTA-751
LB-564 Ultra-high impact B-564、BTA-753
ACRYLIC IMPACT MODIFIERS
LS-21 Weatherability, processability FM-21、KM334
LS-22 Processability, superior surface finish FM-22、D-200
LS-50 Excellent low temperature High impact FM-50
LS-55 Processability, High impact, weatherability FM-55、KM-369、D-520
LS-61 High impact, weatherability KM-355、D-320、FM-40
LUBRICATING PROCESSING AID
LP-175 Good metal release properties P-710、PA-101、K-175
LP-102 Good metal release properties HL-175
LP-103 Excellent processability, good metal release properties P-770
ACRYLIC PROCESSING AID
B-23 Excellent fusion behavior, wider operational condition K-125
LS-530 Good general performance P-530、K-400、 PA-828
NM-530 Better dispersion,weatherability P-530A
LS-540 High melt strength, fast fusions PA-930、K-415
LP - 20 Fast fusions, excellent clarity, good melt flow PA-20、P-551、 K-120ND、PA-910
LP - 21 good melt flow, good surface gloss PA-21
LP - 40 Good surface gloss, high melt strength PA-40、P-531
LP - 50 Fast fusions , ultra-high melt strength K-440
LP - 80 Weatherability, ultra-high melt strength PA-60、K-435
LP - 81 Good melt flow, ultra-high melt strength .
LP - 82 Fast fusions , ultra-high melt strength .
LS - 01 Good general performance, currency grade .
LS - 02 Good fusion fluidity .
LS - 120 Fast fusions , high modify efficiency .
LS - 901 Ultra-high melt strength Blendex 889
CPE135A .good low-temperature flexibility better tearing strength .
JH-181 High heat stabilization and Good Transparency and Weatherability T 181 FS
L-60 promote melt, improve impact strength and surface gloss G60
L-74 good release properties, good efficiency G74
alexs
#32 Сообщение alexs » 20 дек 2010, 17:32
по воздействию на переработку 10F К120 В23 почти одинаковы
К 125 чуть отличается
gammaplast
#33 Сообщение gammaplast » 21 дек 2010, 15:25
не знаю, пока кому давали б-23 вместо 125ого никто разницы не почувствовал...
а вот если кто мне объяснит разницу между 125ым и 175ым?
Fireball
#34 Сообщение Fireball » 21 дек 2010, 15:39
К175 смазывающий можификатор перерабатываемости, он выполняет больше антипригарную функцию, чем контроль плавления...( синонимы Finamod P700, PRO 50....)
gammaplast
#35 Сообщение gammaplast » 23 дек 2010, 11:14
спасибо большое, просто информации мало по 175ому, вот и не понимал.
#36 Сообщение Maks42 » 30 дек 2010, 17:25
Кто-нибудь реально использует К-175 или любой другой акриловый лубрикант?
Нет ли антагонизма с другими внешними смазками?
На самом деле получается антипригарный эффект?
alexs
#37 Сообщение alexs » 09 янв 2011, 15:02
я использую
антагонизма с полиэтиленовыми восками не наблюдаю, дозировку подбирал довольно долго(панель под покраску-2краски+лак)
антипригар? может и ест, но у меня хорошие бельгийские инструменты и служба инструментальной чистки с ультразвуком поэтому сравнивать сложно (до этого с 10F был рецепт)
#38 Сообщение Maks42 » 17 май 2011, 19:33
Fireball писал(а):Кто в экструзии жесткого ПВХ профиля использует или использовал низкомолекулярные смазывающие акриловые модификаторы ( типа paraloid K175, Plastistrength 770)? Насколько их смазывающее свойство отличается от классического нейтрального полиэтиленового или парафинового воска или той же стеаринки? В каталогах красочно описано антипригарное влияние низкомолекулярных модификаторов на границе ПВХ-металл. кто что думает? Еще один момент - в тех же описаниях указано что они не дают эффекта плэйт-аута в отличии от восков. Суть вопроса - стоит ли использовать этот модификатор взамен комбинации нейтрального - окисленного воска ПЭНП?
Я бы не стал, одно другому не мешает и не заменяет.
Еще пару строк тут было viewtopic.php?f=7&t=6240
