Что скажете о данной линии?
Frankie
Одни из производителей предложили такую комплектацию (экструзия листа) (см. ниже), что можете сказать? Какие минусы и на что стоит обратить особое внимание? Какие подводные камни?
ABS Board Production Line
I. Brief description:
1. Suitable material: ABS
2. Output Capacity: 300-450kg/h
3. Product specification: Width:1500mm,thickness:1.5-10mm
4. Operation direction: From Left to right
5. Location: Indoors
6. Humidity degree: ≤85%
7. Temperature 0-40℃
8. Power supply 3-phase, 380V+10% 50Hz
9. Cooling water ≤20℃, ≥0.3Mpa, ~20T/h
10. Compressed air 0.3m3/min, >0.5Mpa
11. Total installation power 170KW
12. Actual power 100KW
13. Installation water 0.5-1 m3/h, recycling water
14. Actual consumption water 10 m3/h
15. Air consumption 8-10 m3/h
II. Machine list of the line
1. SJ-120/30 single screw extruder 1 set
2. Die head & melt pump 1 set
3. Mould 1 set
4. Three-roller calender 1 set
5. Cooling frame 1 set
6. Haul-off machine 1 set
7. Automatic trimming unit 1 set
8. Automatic cutter 1 set
9. Discharge bracket 1 set
III. Terms
Total FOB QINGDAO price USD115,000
Price valid period One month
Guarantee period 12 months for machine
6 months for electrical parts
Service period Lifelong
Payment terms 30% down payment by T/T, 70% before delivery
Delivery time 60 working days after the 30% advanced payment
Package method Suck vacuum package with wooden box outside
Install terms The seller will dispatch one or two engineers to buyer’sfactory to install the machines, but the buyer should get ready for the production conditions, and pay salary of one engineer for USD40 per day, costings of tickets, lodge and meals.
IV. Specific technology parameter:
1.1 Model SJ-120/30
1.2 Screw
Diameter 120mm
L/D 30:1
Material 38CrMoAlA
Surface Treatment Nitrided and Polished
Rotation Speed 10~120r/min
1.3 Barrel
Material 38 Cr Mo Al A
Inner Surface treatment Nitrided, ground
Heating control zones 6 zones
Heating method 380V, 50HZ
Heating power 50KW
Cooling system By blower fan
Cooling power 250w×5
1.4 Gearbox
Material of the house QT200
Gear type Helical gears
Material of the gear 20CrMnTi
Heat treatment of the gear surface Quenching
Bearings Imported high bearing
Lubricating system Press system
1.5 Feeding block
Method Water circled cooling system
Material Q235
1.6 Automatic feeder
Method With vacuum suction method
1.7 Driving motor
Method AC motor, 90KW
Rotation speed 1500rpm
Control system AC Inverter, ABB
Power 3P*380V*50HZ
1.8 Electrical equipments:
Contactor Siemens
Low pressure parts Siemens
Air switch Siemens
Inverter ABB
Thermo-controller RKC/OMRON
Relay RKC/OMRON
Die head style Complex hanger style
Material of die head 5CrNiMo with chromium plated inside
Head of the upper mold lip With adjustable setting and lower mold lip can be replaced
Inner mold with blocking stick, distributor and 3-layer flow path unit ensure three kinds of materials, and color materials be mixed inside the mold
Width of die head 1700mm
Width of products 1500mm
Thickness of products 1.5-10mm
Melt pump Adopts Italy technology and is designed according to high technology, which can improve the production efficiency and excellent quality.
3. Mould
Material heat-resistant high carbon steel, without deformation, high precision
Slippery channel Surface is in shape of clipper-built, which avoid choke the materials
Inverter ABB
Driving power 2.2kw*3
Transmission manner Worm transmission
Width of roller 1700mm
Diameter of roller 400mm
Roughness of roller surface R0.02 (Smooth of finish is above 12 grades)
Surface of roller Plated with hard chromium
Depth 0.06mm
Thickness of roller wall 25-40mm
Dynamic balance <5-10g
Roller throttles 6-8
Deviation of surface temperature ≤2℃
Charge manner middle/down roller charging
Up-down roller adjusting Electro motion, manual
Roller controlling with high-strength heat exchange, three-roller individual water/oil temperature controller that ensures the convenience of adjusting.
5. Cooling frame
Length 10 meters
Material Stainless steel
6. Haul-off machine
Inverter of Haul-off unit ABB
Hauling roller diameter 180mm
Size 180*1700mm
Cylinder clamping Strength of clamping is adjustable; distance is 50mm
Good material chemigum Against friction, against cracking-off
Power of hauling 2.2kw
Trimming unit three dimensions adjustable, automatic trimming based on customer’s requirement
Power 0.75KW*2
Recycling online technique Makes the rate of recycling material can reach 100%
8. Automatic cutter
Pneumatic clamping Adopting linear orbit, ensure the cutting even and equip with automatic sawdust collector.
Power 2.2KW
Length According to customer’s requirement
Width 1700mm
3. Mould 1 set
III. Terms
1.1 Model SJ-120/30
1.2 Screw
Diameter 120mm
L/D 30:1
Material 38CrMoAlA
1.3 Barrel
Heating power 50KW
1.4 Gearbox
1.5 Feeding block
Material Q235
1.7 Driving motor
Power 3P*380V*50HZ
Contactor Siemens
Air switch Siemens
Inverter ABB
Relay RKC/OMRON
3. Mould
Inverter ABB
Depth 0.06mm
5. Cooling frame
Length 10 meters
6. Haul-off machine
Size 180*1700mm
Power 0.75KW*2
8. Automatic cutter
Power 2.2KW
Width 1700mm
- Shadow
1. Запросите спецификацию на сырье. ОБЯЗАТЕЛЬНО!! приемка должна проходить на вашем сырье, а не каком то специальном для этой машины.
2. Необходимо запросить производительность в зависимости от толщины листа. т.к. в конечном счете лимитирующим фактором может оказаться линейная протяжка листа по каландру+ режимы охлаждения.
3. Payment terms 30% down payment by T/T, 70% before delivery
изменить на 60% + 10% после приемки оборудования у заказчика
4. Ничего нет про ЗИП. Желательно включить туда тены, твердотельные реле, регуляторы. Если есть сенсорный панели то могут и ее положить, т.к. они обычно используют устаревшие модели и в случае поломки достать новую будет ОЧЕНЬ проблематично+ если сможете их уболтать пускай скинут исходники для програмирования панелей.
5. Ну и желательно провести приемку непосредственно на заводе в китае
МихалИваныч
Technician
Сейчас этот форум просматривают: Google [Bot] и 8 гостей
